Date/Time: Wed, 27 Nov 2024 12:30:27 +0000
numbers bar spacing
View Count: 900
[2014-09-04 04:50:23] |
User38813 - Posts: 20 |
sir 1 i am trying hard to make visible the numbers charts but not able to do so pls advise me how to increase space. 2 Is there any default setting for number charts . As i want to first use it on default value, and then change according to needs. soryy if i am asking too much with Regards gurpreet Singh |
[2014-09-04 05:34:09] |
1. So that we can better understand this, post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image 2. Unless you have changed the default settings for the Numbers Bars study, when it is added to the chart from the list of studies, it will have the default settings. More information about changing the default settings and resetting back to the original default settings, can be found here: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html&CAID=#CustomDefaultStudySettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-04 05:34:37
