Date/Time: Fri, 22 Nov 2024 21:44:05 +0000
Trade activity log seems different since the latest SC update
View Count: 131
[2024-09-24 20:23:41] |
oliviermo75 - Posts: 19 |
hi i've updated my sierra chart using (2679 64-bit ) when i go to my trade activity log everything look different have you changed it ? i can't find my trades in "Trades" or any other informations. Informations : Version 2679 64-bit Revision 51282 |
tradeActivityLog.jpg / V - Attached On 2024-09-24 20:21:51 UTC - Size: 68.17 KB - 34 views |
[2024-09-24 20:48:07] |
There was a change to the Trade Activity Log earlier this year (2024). Refer to the information at the following link for how to work with the new format: Trade Activity Log: Notes About New Trade Activity Log Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-25 10:03:26] |
ok thanks between you and me before was much better i think it was more clear. you should create a poll and ask us what we prefer. it's an idea thank you again for your reply ;) |
[2024-09-25 13:16:55] |
Sierra_Chart Engineering - Posts: 17145 |
There are no changes with this: i can't find my trades in "Trades" or any other informations.
Only the Trade Activity Log settings interface, is organized better and improved and in a separate window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
