Date/Time: Fri, 22 Nov 2024 21:52:41 +0000
Chart randomly scrolling back
View Count: 107
[2024-09-24 16:01:44]
Wernitschanton - Posts: 24
Hey Team.
My charts just randomly jump back to yesterdays session if i switch between them and there appears to be a right hand fill space which is not supposed to be there
I´ve attached a screenshot where you can see todays open. a little bit of price action and then it just cuts off. Lock fill space is not enabled, the charts are not linked.
For context, i´m using a 49 inch ultrawide. Dont know if thats relevant
Tony
image1.png / V - Attached On 2024-09-24 16:00:59 UTC - Size: 133.99 KB - 35 views
[2024-09-24 17:18:30]
If you scroll the chart forward, does it fill in and show the current day's information?
You changed the default settings for the "Scroll End Color" and "Scroll No End Color", so we are not sure what the indicator in the bottom right of the image is telling us (the pink 7). Is that pink color the End or Not End color?
[2024-09-24 18:14:20]
Hey John.
I´ve figure it out.
I somehow turned on the synchronize charts feature. Sorry for bothering.
Best
Tony
