Date/Time: Fri, 22 Nov 2024 21:18:09 +0000
volume profile & comulative volume delta data is not coming
View Count: 96
[2024-09-24 15:32:56] |
khambolikar - Posts: 9 |
Dear sir, If I open below mention symbols volume profile & comulative volume delta data is not coming. Emini S&P 500, Emini Nasdaq100 & Light sweet crude oil etc. Please solve this issue as soon as possible. Khambolikar 00971504839451 |
[2024-09-24 17:12:34] |
John - SC Support - Posts: 36236 |
Is this a Daily or higher timeframe chart? Also, your data is coming from Interactive Brokers, and their historical data does not include any Bid/Ask information, which could be the reason for what you are seeing if that data was not collected in real-time when connected to Interactive Brokers. With regards to the Volume by Price profile, are you not viewing total volume? If you have the "Volume Bar Calculation Method" set to anything other than "Total Volume" then you will have the same problem as with the Numbers Bars with historical Interactive Brokers data. We recommend using our Denali Exchange Data Feed instead of the data from Interactive Brokers. You will not have the above issues with our data. Refer to the information at the following link: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-24 18:17:05] |
Dear sir, I am trading from UAE. In UAE could you suggest me anyone third party brokers (uae region) connect with sirra chart. |
[2024-09-24 20:39:50] |
We do not know specific brokers around the world, so we can not say what is available in the UAE. We work with Interactive Brokers along with most brokers that use Rithmic, CQG, or Teton for their order routing. But you can use Interactive Brokers for your trading and use our data for your charts. Again, refer to the information for our data at the following link: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
