Date/Time: Fri, 22 Nov 2024 21:11:36 +0000
YM/CBOT live data not working
View Count: 99
[2024-09-24 09:16:17] |
User994203 - Posts: 12 |
Hello, I'm trying to add YM futures to my quoteboard, but I'm not getting any volume through. On the chart, the message says "Historical download skipped". For this, I'm using Rithmic Direct as trading service. ES and NQ futures receive data just fine. When I switch to Teton CME Order Routing, data is receving for YM as well. Please advise. Thanks, |
SC SS 01.PNG / V - Attached On 2024-09-24 09:13:57 UTC - Size: 70.28 KB - 28 views SC SS 02.PNG / V - Attached On 2024-09-24 09:14:10 UTC - Size: 64.89 KB - 30 views Attachment Deleted. |
[2024-09-24 13:26:00] |
Sierra_Chart Engineering - Posts: 17145 |
Your Sierra Chart account is not set up to receive any real time CBOT YM data. That is the problem. Activate this here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed When using Teton order routing you are receiving delayed YM data. Not real time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-24 13:26:34
