Date/Time: Sat, 12 Sep 2026 15:42:40 +0000
Draw Spreadsheet Column
View Count: 1195
| [2014-09-04 03:26:15] |
| User80177 - Posts: 29 |
Hi, I have a Spreadsheet System that colors bars of the Main Price Graph in Subgraph 1. I'd like to draw the output from another columns in the same spreadsheet as a histogram in subgraph 2. The Study Overlay-OHLC allows the selection of individual spreadsheet column but I don't see a way to draw a histogram. Pls advise the best way to achieve this. Thanks |
| [2014-09-04 03:35:07] |
You need to use a separate Spreadsheet study for this.
