Date/Time: Fri, 22 Nov 2024 21:27:09 +0000
Spreadsheet trading and Enable order allocation problem
View Count: 104
[2024-09-23 17:54:48] |
User488241 - Posts: 34 |
Hello, I am having some issues running automated spreadsheet trading with order allocation turned on. The automated trading works fine when using 1 account but things like reversals do not work with order allocation turned on. Is there a setting or something I may be missing that causes this issue? Thank you in advance. |
[2024-09-24 16:56:13] |
Sierra_Chart Engineering - Posts: 17145 |
There should not be an issue. However, make sure you test this using Trade Simulation Mode.: Trade Simulation Do not use a live trading account. Especially Rithmic. You first need to verify you do not have the issue with Trade Simulation Mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-24 21:03:54
