Date/Time: Fri, 22 Nov 2024 21:53:49 +0000
Unable to open
View Count: 103
[2024-09-23 17:32:26]
KevinCanady - Posts: 2
Hello, I am currently unable to open the "Trade Activity Log" window. I've tried the reset windows function as well as updating sierra chart. I am unable to find help with this in the documentation. Thank you for your help!
[2024-09-23 19:06:21]
Make sure you are using the "Window >> Reset Windows" option and then select "Trade >> Trade Activity Log" again from the menu if you still do not see it.
If this still does not work, then refer to the following as an example source we found when searching for "Select Window that is off screen":
https://www.elevenforum.com/t/move-off-screen-window-back-on-screen-in-windows-11.10694/
Date Time Of Last Edit: 2024-09-23 19:06:31
[2024-09-24 20:53:02]
Sierra_Chart Engineering - Posts: 17145
We are going to put out a new release, with a minor change that might help with this.
It will be out, in one or two days.
Date Time Of Last Edit: 2024-09-24 20:53:11
