Date/Time: Fri, 22 Nov 2024 21:29:24 +0000
New version (2679) Profile Problem
View Count: 127
[2024-09-23 15:25:30] |
User750920 - Posts: 278 |
I downloaded the New version yesterday and now ALL the Volume Profiles that are next to (the right of) the TPO profiles for the night session ONLY are a different color. They all used to be black now the day sessions are black like the were (and how I want them) and the night sessions are blue. I made no changes other than downloading and installing the new version. How to rectify this. Thanks
[2024-09-23 18:41:04] |
John - SC Support - Posts: 36237 |
There was a change so that the correct colors are being used for the Value Area of evening profiles if your study is set up for it. Refer to the following: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Color (SG13) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-23 20:07:03] |
So I can change it back if I want (or a different color)? Not sure I will though since as I watched it today I started to like the fact that the evening profiles were easy distinguished, especially when on the same chart as the day profiles. Don't know why I did not think of it before. Thanks
[2024-09-23 20:19:08] |
Yes, you can change it back to the way it was by setting the Input for "TPO Letter/Block Color" to be anything other than "Separate Colors for Day and Evening Sessions". Or you can change the color of the Value Area subgraph's secondary color to change the color of the evening session (the primary color sets the Day session color). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
