Date/Time: Fri, 22 Nov 2024 21:31:37 +0000
Expanded Market Depth Data
View Count: 115
[2024-09-23 14:57:48]
User336325 - Posts: 2
Thank you for the help!
One more question please.
How do I increase the amount of Market Depth that is shown. Right now it is only showing me 30 points up and down and i would like about 100 points.
Your help is appreciated!
[2024-09-23 15:12:24]
Make sure the following setting is set as you want it:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
But, you are getting your data from Rithmic, so you may be limited by their data. You would need to check with your broker on this.
Our Denali Exchange Data Feed has up to 1400 levels of Market Depth. If you want to use our Denali Exchange Data Feed, then follow the instructions at the following link:
Make sure you understand the requirement of the CME Group that you have a live, funded, futures trading account, and that you connect your Sierra Chart to that account at least once a month for verification. Refer to the following for more on this:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
