Date/Time: Fri, 22 Nov 2024 21:53:49 +0000
Value Area fill - Account Support Ticket
View Count: 95
[2024-09-23 13:54:44] |
User495734 - Posts: 28 |
Hi Sierra, I would like adjust my Volume Profile to show the value area from VAH to VAL a different color from the remainder of the volume. Tried to use the Fill top and Fill bottom draw styles for Value Area High Value and Value Area Low value but it doesnt seem to show. Which settings should i use? Thanks |
Screenshot 2024-09-22 204048.png / V - Attached On 2024-09-23 13:54:37 UTC - Size: 55.87 KB - 28 views |
[2024-09-23 15:08:26] |
Refer to the following: Volume By Price Study: Value Area and Outline (SG9) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
