Date/Time: Fri, 22 Nov 2024 21:57:13 +0000
Replicating Main chart window with main tool bar
View Count: 99
[2024-09-22 18:36:02] |
cmack1011 - Posts: 51 |
Hi Currently, I detach a chartbook window when I want to move it to an adjacent monitor. However, the main tool bar with "file" tab does not move with the detached window. IS there a way to have each detached chart have the "file" tab as well. Thank you CNM |
[2024-09-23 13:55:36] |
When you detach a chart, you can have the menu show or not by selecting "Chart >> Show Menu". Refer to the following: Chart Menu: Show Menu (Chart menu) But, this menu will not have all the options that the main window has, such as the "File" pulldown, as it is just the menu items related to that chart. If you want to have a full main window that you can move to another monitor, then you will need to use a Sub-Instance of Sierra Chart. Refer to the following: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
