Date/Time: Fri, 22 Nov 2024 21:32:32 +0000
Addition of Swing Marker OHLC toggles / chat GPT style input/output
View Count: 143
[2024-09-21 09:51:31] |
User676363 - Posts: 71 |
Logic: Time and Price for every tool with OHLC selector available to identify price for time based tools and a date selector available for price based tools available in the anchor properties. Here's the visualization of the idea for the Swing Marker: https://miro.com/app/board/uXjVLcKP_0o=/ I would like to see if we can add date and time logic to every tool similar to what we have for the chart calculator tool? Even for forks and parallel lines so we can see angles and make more tools (like extended rectangle) able to switch to a rotated view at an angle. I would eventually like to see background colors and text labels available for forks and parallel rays and lines because currently I can only highlight horizontally, so there is no time factor and many tools do not support time calculations. Some other tools like the swing marker do not support the idea of OHLC although they can be edited by hand using the anchors. Please feel free to right-click and comment if you see errors and I can correct the design/conception. Thank you P.S. Part of the reason I want to get the text on the screen is: * OCR to extract my notes and put them into AI for summaries. * Export all the text and object properties as easily as copying an image or making a PDF of the chart with the text searchable. * Have a chat window that allows changes to the charts by simply pasting or dictating what we want drawn or summarized and having the AI print out the data or make the drawing updates. |
[2024-09-21 09:56:48] |
Not sure if it would make sense, but if the swing marker could be attached to the other objects as a way to directly manipulate the objects, it might be nice. For example, if you drop a fork on the chart, and the swing marker comes up automatically while the object is selected, we can set the dates and times precisely. If at the same time, for the price axis, the OHLC price tool pops up and we can set the OHLC precisely, then it would provide a very nice visual of where all the time and price anchors are located. Furthermore, if we can then pin any of those time and price anchors with whatever info they show that are interesting, we could have a nice method of making it possible for every tool in SierraChart to be time and price anchored as well as directly manipulated giving it a more miro or tradingview style editing interface that doesn't require opening a dialog in order to set properties of the object. |
