Date/Time: Fri, 22 Nov 2024 21:51:49 +0000
Message Log Pop-Up - Unaactualized data
View Count: 105
[2024-09-20 18:44:23] |
User672558 - Posts: 2 |
Hello, A message log keeps popping up and keeps reapearing. Also, the data doesn't seem to be actualizing. Everything is frozen. See attachments. Can you help me please? |
message log.png / V - Attached On 2024-09-20 18:44:16 UTC - Size: 58.75 KB - 27 views |
[2024-09-20 18:44:52] |
You are having connectivity issues. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
