Date/Time: Fri, 22 Nov 2024 21:42:17 +0000
RE: CURSOR IN REGION 2 IS SHOWING FRACTIONS INSTEAD OF DECIMALS
View Count: 171
[2024-09-20 18:38:36]
User709073 - Posts: 8
Gentlemen,
My Crosshair(not the Cursor) is displaying Fractions in Region 2. I want to change it to Decimals. How do you change this?
Example, Region 2 has an oscillator. Its values are displayed as Decimals, but when I use my Crosshair (not the Cursor), the Y-axis displays the values of the oscillator as a Fraction.
In Region 1, the Crosshair (not the Cursor) displays price as a Decimal as it should be, but in Region 2, the display is shown as a Fraction. I want the Crosshair to display a Decimal.
Thank you.
Date Time Of Last Edit: 2024-09-21 12:56:07
[2024-09-20 18:39:22]
Please get us an image of what you are seeing by following these instructions:
And what is the study that you have displayed in Region 2?
[2024-09-21 12:20:29]
Gentlemen,
My Crosshair (not the Cursor) is displaying Fractions in Region 2. I want the Crosshair to display Region 2 in Decimals. How do you change this?
Example, Region 2 has an oscillator stochastic, or ergodic, or rsi, it makes no difference. Its values are displayed as Decimals, but when I use my Crosshair, the Y-axis displays the values of the oscillator as a Fraction.
In Region 1, the Crosshair (not the Cursor) displays price as a Decimal as it should be, but in Region 2, the display is shown as a Fraction. I want the Crosshair (not the Cursor) to display Decimals in Region 2.
Let me say it another way. With the Crosshair, Region 1 displays the value in Decimals, Region 2 Displays the values in Fractions. I want Region 2 to display Decimals using the Crosshair not Fractions.
Thank you.
Joseph Feinberg
Date Time Of Last Edit: 2024-09-21 13:00:08
Private File
[2024-09-21 22:48:56]
Please get us that chart by following these instructions:
