Date/Time: Fri, 22 Nov 2024 21:05:49 +0000
calculation of the sitting position
View Count: 108
[2024-09-20 18:36:59]
User433987 - Posts: 2
Hello, how can I set automatic calculation of the sitting position and stop loss? I would like the stop loss to always be of a similar value regardless of the number of ticks (mini contracts). Regards
[2024-09-20 18:37:49]
John - SC Support - Posts: 36236
What is the calculation you are wanting?
[2024-09-23 06:45:10]
Np. Ustawiam stałą wartoś SL na poziomie 100$ na micro kontakcie GC (złoto) gdzie warto 1 tika = 1$. Chciałbym aby ustawiając pozycję oczekującą a nastepnie przesuwając SL dopasowywała się ilość kontraktów ws do stałej wartosci 100$. Np. Jeżeli SL = 10 tiko to otwieram pozycję 10 micro kontaktów a jeżeli SL = 6 tików to otwieram 16 micro kontraktów.
E.g. I set a constant SL value of $100 on the GC micro contact (gold), where the value is 1 tick = $1. I would like to adjust the number of contracts to a fixed value of $100 by setting the pending position and then moving the SL. E.g. If SL = 10 ticks, I open a position of 10 micro contacts, and if SL = 6 ticks, I open 16 micro contracts.
[2024-09-23 14:47:13]
You would have to create a custom trading study to do this. There is no built-in mechanism to determine the number of ticks for the Stop based on the quantity. Refer to the following:
Automated Trading From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
