Date/Time: Fri, 22 Nov 2024 22:20:17 +0000
Is there a function to confirm the order before execution (after submitting the order)?
View Count: 110
[2024-09-20 14:59:41]
DLi - Posts: 16
Dear Sierra Team,
Regarding the trading tool, is there way we could have entry line and stop loss line show up on the chart before executing the order?
For example, one would like to long ES at 5000 (entry line) with a 5 pt stop at 4995 (stop loss line), is it possible to see the lines prior to order being executed? The execution would be activated via a confirmation / or cancellation prompt.
Than you!
[2024-09-20 17:51:55]
There is not a built-in way to see the lines prior to the orders being sent.
Just so you are aware, if you turn on Confirmations, you will be prompted with the information for the order, where you can see the Entry Price, Stop Price, and Target Price. You then have to select OK for the orders to be sent. Refer to the following:
Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific)
