Date/Time: Fri, 22 Nov 2024 21:23:44 +0000
Please help me understand this message in the Message Log
View Count: 119
[2024-09-20 14:45:01]
User846910 - Posts: 8
I am using sub-instances. I periodically get this message:
DTC Protocol server | Incoming connection from 185.11.61.253. | 2024-09-20 02:36:34.891
DTC Protocol server | Rejecting connection from 185.11.61.253. | 2024-09-20 02:36:34.891 *
The IP address changes but they are always from Russia. Do I have to be concerned and is there something I can do to prevent this?
[2024-09-23 16:04:35]
Sierra_Chart Engineering - Posts: 17145
Yes you should be concerned. You should be running a hardware firewall which is inherently is the case when your computer is connected through a router to the Internet.
Date Time Of Last Edit: 2024-09-23 16:04:41
