Date/Time: Fri, 22 Nov 2024 22:26:30 +0000
Customization of Order Allocation for different accounts
View Count: 99
[2024-09-20 11:25:14]
Eranox - Posts: 26
I'm using Sierra Chart to place orders simultaneously on multiple accounts using the Order Allocation function. Is it possible for just one of the copied orders to use a different multiplier? For example, to the current 6 copied accounts with a one-to-one ratio, I would like to add another one with a one-to-three ratio to be used simultaneously with the other 6, so a total of 7 copied accounts.
[2024-09-20 14:45:37]
The "Multiplier" option that is available in the Order Allocation to Trade Accounts is set per trade account. So you can set this to be different for each individual account you add. Refer to the following:
Order Allocation to Trade Accounts: Allocation Trade Account Multiplier
