Date/Time: Fri, 22 Nov 2024 22:09:26 +0000
Footprint Pullback column not always visible
View Count: 173
[2024-09-20 09:33:41] |
rastacat95 - Posts: 2 |
Is there a way to keep the footprint pullback visible? I currently have scale set to constant range; Constant Range Scale Mode = Keep Last Bar Within View. This Keeps the actual footprint bar in view but cuts off the pullback column. Any help would be greatly appreciated! https://www.sierrachart.com/image.php?Image=1726824687365.png https://www.sierrachart.com/image.php?Image=1726824768766.png |
[2024-09-20 10:22:04] |
User431178 - Posts: 540 |
I currently have scale set to constant range; Constant Range Scale Mode = Keep Last Bar Within View. This Keeps the actual footprint bar in view but cuts off the pullback column. That applies only to the vertical scale. Try scrolling left so that there is sufficient space for the pullback column, then enable lock fill space. Working With Charts: Locking the Right Side Fill Space |
