Date/Time: Fri, 22 Nov 2024 22:13:34 +0000
Copying of Chartbooks from Multiple Instances of Sierra Charts
View Count: 120
[2024-09-20 08:41:09]
bobstone249 - Posts: 28
Hi, my initial enquiry has been resolved, I had failed to use the command Edit> Translate Symbols to Current Service.
However, I do have an annoying thing which I can't resolve. I'm using Windows 11 and one of their apps called Powertoys which has a window manager utility called "FancyZones". I have created a custom snap layout to incorporate a Footprint/DOM/VWAP Chart/Market Profile Blocks (I have 2 identical external monitors running off my computer). The issue is that I have to configure the snap layouts of my workbooks every time I load them up. For some reason, the system is not remembering the snap layout/workbook config I select. I always select save when closing chartbooks. Can you help me resolve this?
Many thanks
Rob
Date Time Of Last Edit: 2024-09-20 10:03:40
[2024-09-20 14:24:24]
We can not help with this. The Windows Powertoys are not supported items by Microsoft to start with. And we have no idea of how that tool is working with the windows in order to snap them into a certain position.
