Date/Time: Fri, 22 Nov 2024 21:26:38 +0000
How to add Eurex Trading/Routing when using Teton with AMP broker?
View Count: 184
[2024-09-20 05:48:21]
User558487 - Posts: 2
I am currently trading the CME using the Teton Routing service with broker AMP futures.
In the near future, I would like to also trade the Eurex. My understanding is that to trade Eurex, I would need another trading service (like Rithmic).
If I get Rithmic for Eurex, does it mean that I would need to run 2 instances of Sierra (one each for Teton & Rithmic)?
With these 2 instances of Sierra addressing (linked) to the same brokerage account (number) at AMP, would there be any problems with calculating the Cash Balances in the Trade Account Monitor? I mean in the event that I have 2 outstanding positions, one each with Teton and Rithmic, would the Trade Account Monitor reflect the correct (Net) Cash Balances?
Thanks.
[2024-09-20 14:17:25]
John - SC Support - Posts: 36237
You are correct in that you would need to setup another trading service with AMP, either Rithmic or CQG, in order to trade EUREX. And you would want to have another installation of Sierra Chart setup in order to access that service.
But what you are missing is that when you setup this other service with AMP, it will need to be a completely different account. So it will not be tied to your other account that is using Teton. Therefore, the balances for each will be completely separate.
The instructions to install a second Sierra Chart are at the following link:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2024-09-20 17:21:46]
Thanks for your clarification. It was most helpful.
Any updates on Teton Routing supporting Eurex trading?
[2024-09-20 18:12:55]
Highly doubtful we would implement order routing for EUREX. The regulations in Europe for implementing this have increased dramatically over the last few years and make it prohibitively difficult for us.
