Date/Time: Fri, 22 Nov 2024 22:33:41 +0000
Toggle between DOMs with hotkeys
View Count: 114
[2024-09-20 03:31:06]
User560704 - Posts: 12
Hi there,
I was wondering if there is a hotkey to quickly switch between DOMs across 2 symbols/products for example?
As i understand having specific hotkeys to execute on the DOM across multiple symbols is not supported, however, a shortcut to toggle between quickly would do the job.
Thanks for your assistance!
[2024-09-20 14:02:53]
The only options for moving between charts (DOMs) are the "Previous Chart" and "Next Chart", which are assigned to F4 and F9 by default.
