Date/Time: Fri, 20 Sep 2024 01:00:13 +0000
Quote Board
View Count: 975
[2014-09-03 21:01:35] |
User21113 - Posts: 62 |
Saved symbol lists will not load. Populated a quote board with stock symbols. Saved the quotes, File >> Save Symbol List As, saved the file as Tech.symbollist. The title bar shows QuoteBoard | Tech When another list is selected through either File >> Load Symbol List Settings >> Set Symbol List >> Import The current quotes are removed and nothing is imported. The data directory is opened and each symbollist file is opened in a text editor and they show quote tickers. |
[2014-09-03 22:52:21] |
Al SC Developer - Posts: 434 |
This should be resolved in the latest release (1187).
