Date/Time: Fri, 22 Nov 2024 22:08:41 +0000
Color customization for Chart Detail Bar
View Count: 108
[2024-09-19 20:42:02]
User8135477 - Posts: 115
I'd like to change the colour of the text at the top of each chart.
I tried to go through the graphics settings for each option, but cannot seem to find the one that controls this part.
What is the name of the setting for this region? Please see screenshot for further clarification regarding the area I'm trying to adjust.
Private File
[2024-09-19 20:44:50]
We assume you are referring to the Chart Header.
That text color is controlled with the "Chart Text" color. So you can not change it separate from the other text in the chart. Refer to the following:
Graphics Settings: Chart Text
