Date/Time: Wed, 27 Nov 2024 13:01:42 +0000
inconsistent placement of arrows in macd crossover system in range charts
View Count: 1295
[2014-09-03 20:50:38] |
User70152 - Posts: 20 |
I am using macd crossover system indicator on range charts. It does not places arrows at right spot above or below the candle, some of them actually get embedded in the candle and difficult to see. I have played around with arrows offset percentage settings and tried settings from 0-200 but no help. Works fine in time, tick and renko charts but not in range charts. See screenshot. Setting on this screenshot is with 0 offset. http://www.sierrachart.com/image.php?l=1409777065136.png |
[2014-09-04 18:26:25] |
This has to do with the High and Low data for this type of chart. There really is no solution to this. More information can be found here: https://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
