Date/Time: Wed, 23 Apr 2025 03:09:22 +0000
How to extend service package 11 use time by 48 hours?
View Count: 214
[2024-09-18 20:28:47] |
BtcfuturesToMoon - Posts: 81 |
I believe this option was available a while a go...?
[2024-09-18 21:14:35] |
John - SC Support - Posts: 39428 |
When your Usage Time ends, you can go to the Main Control Panel for your account and select the option for "Services and Payments >> Emergency Account Activation" from the pulldown menus near the top. You will be given 5 days of Usage Time, but that time will then be removed when you pay for your next package. To get to your control panel, select "Help >> Account Control Panel" from within your Sierra Chart software. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-18 21:31:40] |
Sweet. Thank you, sir. ❤️
[2024-12-15 13:10:41] |
User717569 - Posts: 15 |
Hi, I’m unable to use the emergency service for package 11. Is there any way to extend it like another 48 hours? I will get paid on Wednesday. Thank you.
[2024-12-15 19:30:04] |
Sierra_Chart Engineering - Posts: 19307 |
This is now done.
