Date/Time: Sat, 23 Nov 2024 02:19:17 +0000
Graphiques non visibles
View Count: 96
[2024-09-18 15:02:06] |
Scarlet - Posts: 1 |
Bonjour, Le graphique ainsi que les règles verticales et horizontales ne sont pas visibles. |
[2024-09-18 17:02:53] |
It sounds like your chart is completely blank. Since you are on a trial, you have limited data you have access to. Refer to the following: Sierra Chart Trial Account And refer to the following for how to get started using Sierra Chart: Getting Started, Opening Charts and Basic Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
