Date/Time: Sat, 23 Nov 2024 01:55:51 +0000
Automatic Fibonacci levels for a session.
View Count: 123
[2024-09-18 04:45:53]
hermeticio - Posts: 10
cordial greeting support.
Expose a simple idea, but I can't find a solution.
Idea: I seek to achieve automatically to be shown in the graph some lines of maximum and minimum in a given session. also to be able to mark the Fibonacci levels from this maximum and minimum.
Achievements: With the High/Low for time indicator period you can establish or find this maximum and minimum.
Pending: seeking to automatically marked the Fibonacci levels from this studio. I thought that the next study called Auto Retracement/Projection could make these levels mark depending on the previous study.
Thanks for reading.
Date Time Of Last Edit: 2024-09-18 04:47:44
[2024-09-18 14:16:19]
The easiest way to do this would be to use the Spreadsheet Study, which will allow you to create each level in each column. The formula for the first level of 23.6% would be the following:
=((ID1.SG1 - ID1.SG2) * .236) + ID1.SG2
Where ID1 is the ID of your High/Low study, SG1 is the High subgraph of that study, and SG2 is the Low of that study.
Refer to the following:
Using the Spreadsheet Study
[2024-09-19 01:43:39]
Making your recommendations I have the following formula.
= ((ID3.SG1@3-ID3.SG2@3)*0.382) +ID3.SG2@3
To which gives a number value.
How could I make this number value appear as a line in the graph?
Date Time Of Last Edit: 2024-09-19 01:44:36
[2024-09-19 14:18:41]
You should have that value in the entire column where you entered it if you are using the Spreadsheet Study. Make sure you are using the Spreadsheet Study and not just a Spreadsheet.
With the Spreadsheet Study, the first four calculation columns (K, L, M, and N) are set to display on as lines. If you are using more than those columns then you would need to set the Draw Style for the subgraph associated with each column to "Line" or whatever draw style you want. Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
