Date/Time: Sat, 23 Nov 2024 01:37:56 +0000
BTC CME
View Count: 113
[2024-09-17 23:18:26] |
User989530 - Posts: 31 |
Hi Support, Which broker is the best one to trade BTCU24.CME on Sierra Charts? Also i would like to know how much volume in usd has. Regards |
[2024-09-18 11:33:14] |
UserOne - Posts: 40 |
You will find the answer to your volume related question here: https://www.cmegroup.com/markets/cryptocurrencies/bitcoin/bitcoin.volume.html
[2024-09-18 14:52:37] |
The only recommendation we can make in terms of brokers is to use one that supports our Teton Order Routing Service since you are wanting to trade the CME Group. Refer to the information on our Teton Order Routing at the following link - there is a list of brokers that support this service in Step #2 of the Setup Instructions on this page: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
