Date/Time: Sat, 23 Nov 2024 01:46:51 +0000
risk management settings
View Count: 130
[2024-09-17 18:54:32] |
mizzymart23 - Posts: 3 |
I have been able to get the risk management tool in the (global loss/profit management) to work but have not been able to reset it. For example, I would like to have the risk manager lock me out of trading for 15 minutes when a daily p/l is at -250 and then lock me out for the day when a daily p/l hits -500. I have been able to get the risk manager to flatten and lock me out for a set amount of time but then the risk manager becomes disabled for the day? Is there a way for me to then reset this after the 15 minute lock out; to then lock me out for the day at a different negative p/l value (-500)? Thanks for your help. |
[2024-09-17 20:23:10] |
There is not a way to have the "Global Profit/Loss Management" lock you out for two different time periods with a single setup. You could set it up to lock you out for 15 minutes after a loss of 250, and then you could set it up to "Lock for Day" if you hit a loss of 500. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
