Date/Time: Sat, 23 Nov 2024 02:17:30 +0000
Rhithmic and Denali Data Feed
View Count: 95
[2024-09-17 14:50:33] |
atariaf - Posts: 6 |
I have attached my Rhithmic account to Sierra Chart. I have read the support pages and do not intend to use the Rhithmic data or historical data. From my understanding I can use the Deanli data and just use the Rhithmic connection to make trades with my Rhithmic account. I already have a Denali Data Feed. I believe I have set the Rhithmic setup correctly (did not add credentials for data). How can I check/confirm that I am currently using the Denali Exchange Data Feed but trading on the Rhithmic account? Thanks in advance! Regards, Larry |
[2024-09-17 16:20:27] |
The things to check are the following: - Do you have an active exchange - Yes you do. - If you are getting data for the CME Group, then is your "Verified Until" date set to some time in the future - Yes, it is set to "2024-10-13". - Is the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" set to "Yes" - You need to check this. If the above are set properly, then you are getting the data from our Denali Exchange Data feed. Also, if you have the symbol set to display in your Chart Header, then you will see a symbol of '[M]' (no quotes) showing after the symbol. That '[M]' indicates the data is coming from Sierra Chart. You can view the "Verified Until" date for your account at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
