Date/Time: Sat, 23 Nov 2024 01:50:15 +0000
Filled Order Data doesnt show
View Count: 93
[2024-09-17 11:47:50] |
User706091 - Posts: 4 |
Hello, Why don’t I see the actual trades I took in the exported file? It only shows canceled, pending, or order status information. Is there a way to export only the filled order data and executions? That would be great! I would like the data in a similar format to the file I’ve attached. I want the data to be exported form the: Trade Activity tab. If the executed trade data is already present in the trade activity tab, can you pinpoint where and under what status? " |
Sierra Chart_CorrectFile copy.txt - Attached On 2024-09-17 11:47:20 UTC - Size: 1.28 KB - 66 views Attachment Deleted. |
[2024-09-17 14:12:04] |
To export just the Order Fills from the Trade Activity Log, you need to set the DisplayOptions to show just the Order Fills. Then when you export/save the information it will be what is displayed. Refer to the following: Trade Activity Log: Saving to a Text File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
