Date/Time: Fri, 18 Sep 2026 02:35:10 +0000
Show/Hide Peak outside of Value Area
View Count: 664
| [2024-09-17 05:31:29] |
| User727273 - Posts: 6 |
Dear Support, I have a chart based on TOP and VbP studies. In the VbP study, I wanted to highlight the valleys, but when activating it, the study also considers the High/Low as valleys... In my other charts where I have VbP, that doesn't happen. Is there a way you could help me set the parameters so my study doesn't show the High/Low as Valleys ? Best regards |
| [2024-09-17 13:53:05] |
| John - SC Support - Posts: 47930 |
Refer to the following: Volume By Price Study: Include High/Low in Peaks and Valleys For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-17 15:35:05] |
Thank you John, I tried to toggle YES/NO for Include "High/Low in Peaks and Valleys", but it doesn't solve my issue. The High and Low of the day are still shown as Valleys and extended until future intersection. Thus they are confusing with my Valleys lines. Is there another setting that disturb the way Valleys are shown ? |
| [2024-09-17 17:14:49] |
Please get us a chart that shows the issue you are having by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-18 06:40:35] |
Hello John, here is my chartbook.
Private File |
| [2024-10-02 06:51:34] |
Hello John, coming back to my issue, did you manage to figure out what is wrong with my chartbook ?
| [2024-10-02 13:57:02] |
So sorry, this got dropped somehow. But in looking at this again, we do see what the issue is. You have the option for "Include High/Low in Peaks and Valleys" set to "Yes" on the TPO Inputs. This is causing the Peaks and Valleys on the Volume Profile to also include the High and Low. Make sure both options (on the TPO and on the VbP) are set to "No". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-02 16:05:44] |
Thank you John ! that works perfectly fine now
