Date/Time: Sat, 23 Nov 2024 01:55:42 +0000
Moving unfilled orders with keyboard shortcuts?
View Count: 130
[2024-09-17 02:10:58] |
FelixAndres090519 - Posts: 9 |
I think I'd be able to have better entries with a push of a button than by clicking and dragging, as I believe the order isn't placed at a level until the mouse button is released. Would be great, especially in the mornings when the market is moving quickly. Is there a way to configure an unfilled Buy Stop order to move down one tick, and a Sell Stop order to move up one tick, using Keyboard shortcuts? Thanks!
[2024-09-17 13:18:31] |
There are keyboard shortcuts to do this, such as "Stop Order Tick Up". Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-17 13:29:48] |
Hey John, thanks for the reply. I do have these set up, but the move my stop loss. I guess what in trying to do is something along the lines of "non-attached limit order tick up/down", but with a stop entry. Any way to do this? |
[2024-09-17 13:33:33] |
Yes, there are also keyboard shortcuts for "Non-Attached Limit Order Tick Up/Down".
