Date/Time: Thu, 31 Oct 2024 10:13:09 +0000
How do I manually Draw standard deviations
View Count: 95
[2024-09-16 19:53:43]
User776992 - Posts: 8
Question 1: I'd like to be able to manually draw a standard deviation that would show the expansion
of price down or up depending on the area that I'm drawing from.
For example, if I draw from arrow 1 to arrow 2 to show me a standard
deviation listing of price points from 0 to -4 or vice versa if I drew from arrow 2 to arrow 1
showing me a standard deviation list from 0 to -4, I hope that makes sense.
The arrow 3 would be one of the targets of the expansion area as it
correlates with the standard deviation.
https://www.sierrachart.com/image.php?Image=172634985126.png
Question 2: How do i duplicate a button in the customized tool bar meaning can I have two price expansion button side by side each with different settings?
Thank you
imageFib Retracement 1.png / V - Attached On 2024-09-16 19:53:37 UTC - Size: 42.98 KB - 31 views
[2024-09-16 19:57:27]
John - SC Support - Posts: 35639
We really do not understand what you are wanting to do. In addition, we are not sure what the "Fib Retracement" page that you display is in reference to.
We do have a "Price Retracement" tool that may be what you are looking for. Refer to the following:
Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools
