Date/Time: Thu, 31 Oct 2024 10:12:42 +0000
Copying settings from one instance to another
View Count: 91
[2024-09-16 18:19:58]
L2Ltrades - Posts: 60
I have two accounts going on. I recently installed the second instance of Sierra in a different folder. How do I copy the exact same graphic settings from one instance to another?
[2024-09-16 19:15:25]
John - SC Support - Posts: 35639
The Graphics and other Global settings are contained in the file named "Sierra4.config". You would need to copy this file from the one instance to the other instance. Refer to the information at the following link for what is contained in each file:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
