Date/Time: Sat, 23 Nov 2024 01:57:44 +0000
Numbers in numbers bar are incorrect
View Count: 134
[2024-09-16 17:56:04] |
Anmol krishna - Posts: 2 |
Hello, I notice that the numbers in the number bars study are showing incorrect for CME futures data, over the weekend when I was reviewing my trades, the numbers were fine but I don't know why its different today. I can see many zeros and volumes are abnormally low. All I did today was a symbol rollover. Screenshot attached. I'm also attaching the study I use. Regards, Anmol |
Attachment Deleted. Screenshot 2024-09-16 195409.jpg / V - Attached On 2024-09-16 17:55:22 UTC - Size: 363.97 KB - 38 views V2_Footprint and trading DOM.Cht - Attached On 2024-09-16 17:55:37 UTC - Size: 26.01 KB - 67 views |
[2024-09-16 19:13:57] |
We are not understanding the issue. The symbol rolled over, so you are looking at data for a completely different symbol than what you were viewing previously.
[2024-09-16 21:44:02] |
User150671 - Posts: 69 |
Not sure exactly your issue, but when following option is set to No I have noticed discrepancies in what actually traded on the DOM vs what Numbers Bar Study reports: Numbers Bar Study > Line 118: "Require 1 Tick Intraday Data Storage Time Unit" to YES Also, you're trading MES. Any reason you aren't doing it off a chart of ES? If you want to you can do as follows: Chart Settings > Symbol: ESZ24-CME Trade and Current Quote Symbol: MESZ24-CME Use As Trade Only Symbol: YES |
[2024-09-17 05:28:20] |
Thank you. Appreciate the quick and helpful responses. Adjusting the symbol has helped me display the correct volumes.
