Date/Time: Sat, 23 Nov 2024 02:00:38 +0000
Source code for Trading: Position Average Price study
View Count: 133
[2024-09-16 17:54:15]
User454729 - Posts: 18
Hi there,
I have searched for the source code in ACS_source folder for the above mentioned study but can't find it. Please direct me to the CPP file that has it. Thank you.
[2024-09-16 19:12:34]
The source code for this study is not available. Refer to the following:
How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available
[2024-09-17 03:59:38]
Hi John, thank you. I was trying to get this study onto my DOM. Do you have any ideas how I can do this?
[2024-09-17 13:42:29]
It really will not work on a Trading DOM, as the Trading DOM doesn't have the same concept of bars like a standard chart. So the line for the Position Average Price will not display properly on a Trading DOM.
But you have us a bit confused, as you should have the Position Line showing, which can show the Position Average Price and is at that level. Is there something in particular you are looking for?
