Date/Time: Thu, 31 Oct 2024 10:13:03 +0000
Futures symbol rollover in excluded chart
View Count: 87
[2024-09-16 12:54:33]
User512353 - Posts: 38
SC2677
symbol: ES
first ES intraday chart has
Chart Settings >> Symbol >> Automatically Rollover Futures Symbol = No
Chart Settings >> Symbol >> Continuous Contract (List): Continuus Futures Contract - Volume Based Rollover, Back Adjusted
second ES intraday chart has
Chart Settings >> Symbol >> Continuous Contract (List): None
Select first chart, select
Chart >> Perform Futures Symbol Rollover
This action will also rollover the second chart, although by the chart settings this is not wanted.
[2024-09-16 18:25:38]
John - SC Support - Posts: 35639
Sierra Chart is setup to rollover all charts that have the same symbol when you select "Chart >> Perform Futures Symbol Rollover". Refer to item #4 at the following link:
Changing to a New Futures Contract Month: Changing to a New Futures Contract Month
Therefore, you would have to change the symbol back to the previous contract for that one chart, if you do not want it to be using the new symbol.
