Date/Time: Thu, 31 Oct 2024 10:13:09 +0000
Chart DOM
View Count: 136
[2024-09-16 03:48:54] |
User8135477 - Posts: 115 |
I have a few questions regarding the DOM: 1. Is it possible to move the Buy column to the Right and the Sell column to the Left? 2. Is it possible to increase the font size of the Price (and not just the Quantities)? 3. Rather than using the Left/Right click for market & limit orders within just one column, is it possible to have an additional column and use the left click only for each of the order type? 4. Is it possible to place an OCO order on the DOM? |
[2024-09-16 09:19:57] |
User150671 - Posts: 67 |
1. On DOM: Trade > Customize Trade DOM Columns 2. Global Settings > Graphic Settings > Fonts > Chart Text (Global) # this controls Font size of the value scales (price) 3. Global Settings > Chart DOM settings > Order Types # What you are asking isn't quite possible I believe, however you can set the mouse actions you want here, and can likely achieve what you need. 4. You can set Attached Orders and OCO groups through Trade > Open Trade Window for Chart. For more detail: Attached Orders: OCO Group (Group) |
[2024-09-16 12:44:02] |
Thank you for the response. To clarify, regarding #4, I was wondering if it's possible to enter an OCO Limit & Stop order on the DOM for an existing position?
[2024-09-16 12:46:46] |
I think you can do this, however been a while since I played with attached orders. Suggest you read the link I posted above and see if your query is answered there. |
[2024-09-16 12:59:29] |
The link only shows how to achieve it with the Trading window. I am aware of how to achieve it while trading directly on the chart, but I was wondering whether it is possible to enter it directly onto the DOM. With regards to increasing the font size on the DOM - is it possible to do this for the DOM that is directly attached to the chart? (ie. the DOM that appears on the vertical price scale when activated from Trade -> Trading Chart DOM On |
[2024-09-16 18:30:51] |
John - SC Support - Posts: 35639 |
The "Order Types" that you can configure for the Chart/Trading DOM columns does not include the option for "Send Attached Orders by Position/Price". Therefore, this is not supported directly. Refer to the following: Global Trade Settings Windows: Order Types (Global Settings >> Chart DOM Settings) The same information given above applies to the Chart DOM regarding the font. The Price Ladder font is controlled through the "Chart Text" font. You can have a different font for the Market Depth data, as those are controlled through the "DOM Quantities/Sizes" font. Refer to the following and the item below it: Graphics Settings: Chart Text - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
