Date/Time: Fri, 22 Nov 2024 22:43:32 +0000
Using Rithmic on free trial
View Count: 125
[2024-09-16 03:09:32] |
robTrader - Posts: 2 |
Hello, I am trying to follow the steps at https://help.topstep.com/en/articles/8284183-sierra-chart-connection-instructions while using a free trial, but for step 4, the Sierra chart application says the current package does not support Rithmic Direct. Is there a way to enable this for the free trial package? Thank you!
Date Time Of Last Edit: 2024-09-16 03:09:44
[2024-09-16 16:36:16] |
You can not connect to external services while on a trial. And, in general, in order to connect to trading or data services, you need to be on one of the "Integrated" packages. Refer to the following for information on the packages: Description of Service Packages and Pricing When you are ready to change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions Our instructions for connecting to Rithmic are at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-19 01:52:39] |
Okay, is it possible to get a free trial of one of the integrated packages? It's hard to tell if I want to use this otherwise.
[2024-09-19 14:21:33] |
The only trial we have is what you are on now. You would need to pay for the Integrated package.
