Date/Time: Thu, 31 Oct 2024 10:13:07 +0000
Tick Chart
View Count: 105
[2024-09-15 16:17:39]
MarketBeast - Posts: 25
Similar to a 1000/2000 tick chart, is it possible to have 10 million/50 million trades per bar tick chart? Currently the max seems to be around 1 million per bar which is not even close to daily chart and I don't want to use historical chart because I'm a micro scalper. I would appreciate your help. Thank You!
[2024-09-16 15:48:39]
John - SC Support - Posts: 35639
We have gotten to as high as 500 million trades per bar. We are not sure the exact limit.
Make sure you have enough data loaded to cover the total number of trades per bar you want, and you probably also want to turn off the option for "New Bar At Session Start". Refer to the following:
Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu)
