Date/Time: Thu, 31 Oct 2024 10:12:48 +0000
Numbers bars calculated values 2 - Pull/Stack difference
View Count: 143
[2024-09-15 10:41:19]
v1real - Posts: 1
Hi, I have question about "Ask/Bid Pull/Stack Sum Diff" in Numbers bars calculated values 2. Is it calculated correctly? Because, when I have negative sells, and positive buys, I have difference negative and this makes no sense. It is long situation, but with negative number and it is very confusing.
Thank you
https://www.sierrachart.com/image.php?Image=1726396726497.png
[2024-09-16 14:57:46]
John - SC Support - Posts: 35639
The information is correct. The formula for that item is "Total Ask Pulling Stacking" - "Total Bid Pulling Stacking". Therefore, for the image you show, this would be the following:
-426 - 670 = -1096
The above information for the subgraph is given at the following link:
Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions
