Date/Time: Thu, 31 Oct 2024 10:13:09 +0000
Candlestick Pattern Finder Study Bug?
View Count: 106
[2024-09-14 18:56:49] |
user_xyz - Posts: 411 |
Did something change on this study not allowing changing Pattern 2-6 Subgraph settings? Changing Draw Style on any Pattern 2-6 (SG2-SG6) just reverts back to Ignore. I thought at one point I could change Draw Style for a specific pattern to symbol eg. circle |
[2024-09-16 14:50:41] |
John - SC Support - Posts: 35639 |
There has not been any recent changes to this study, it has always worked in this way. If you want a circle at the High or Low instead of the text, then you can use the "Study Subgraph Reference" study and set it to reference the particular subgraph you want and set the subgraph for the Study Subgraph Reference Draw Style to be either "Point on High" or "Point on Low". Refer to the following: Study Subgraph Reference Chart Studies: Point On Low (ACSIL: DRAWSTYLE_POINT_ON_LOW) If you want to use some other draw style, then you would need to use the "Color Bar Based on Alert Condition" and set the condition for the particular pattern you are wanting and then setup the Color Bar Based on Alert Condition appropriately. Refer to the following, in particular the section on "Drawing Arrows/Text or Other Styles at the High or Low of Bars": Color Bar Based on Alert Condition And note the section on alerts on the Candlestick Pattern Finder documentation. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
