Date/Time: Fri, 20 Sep 2024 00:57:08 +0000
Putting 2 indicators, of two different time frames on one chart
View Count: 957
[2014-09-03 09:52:19] |
ripsdips - Posts: 143 |
is it possible to put 2 indicators, of two different time frames on one chart?
[2014-09-03 17:07:34] |
Yes. Refer to this help topic: https://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
