Date/Time: Sat, 04 Jul 2026 04:34:02 +0000
[Programming Help] - Using ACS Control Bar Buttons with sc.AutoLoop=1
View Count: 678
[2024-09-14 07:04:46]
Alexander - Posts: 18
In the working example for the ACS Control Bar Buttons function, in the /ACS_Source/studies.cpp file, the Autolooping is set to OFF.
Is it possible to get a simple working example of using the ACS Control Bar Buttons function when Autolooping mode is enabled?
For example, this code doesn't work for me (pressing the button only affects the last bar):
if (sc.SetDefaults)
  sc. AutoLoop = 1;
  sc.ReceivePointerEvents = ACS_RECEIVE_POINTER_EVENTS_ALWAYS;
  return;
if (sc.MenuEventID >= ACS_BUTTON_1 && sc.MenuEventID <= ACS_BUTTON_150)
sc.SetCustomStudyControlBarButtonEnable(sc.PriorSelectedCustomStudyControlBarButtonNumber, 0);
int Lenght = 5;
sc.MenuEventID = ACS_BUTTON_1;
if(sc.PointerEventType == SC_ACS_BUTTON_ON) Lenght = 20;
if(sc.PointerEventType == SC_ACS_BUTTON_OFF) Lenght = 50;
sc.MovingAverage(sc.BaseDataIn[SC_LAST], sc.Subgraph[0], MOVAVGTYPE_SIMPLE, Lenght);
Thank you in advance
Date Time Of Last Edit: 2024-09-14 08:00:34
