Date/Time: Fri, 20 Sep 2024 04:02:25 +0000
Range bars incorrect when defining market hours
View Count: 967
[2014-09-03 09:24:33] |
User12676 - Posts: 70 |
Range bars incorrect when defining market hours in chart settings to be daily session only. Check attachment. I have defined market hours to be 17:30 - 22:00. And we get a huge decline from 17:30. This pattern repeats daily.
Attachment Deleted. screen.jpg / V - Attached On 2014-09-03 09:23:22 UTC - Size: 119.75 KB - 361 views |
[2014-09-03 15:28:47] |
Set the chart to 1 minute per bar and post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-03 15:29:00
[2014-09-17 11:56:00] |
Here are 2 images, first one is with ticks http://www.sierrachart.com/image.php?l=1410954868622.png This one is with 1 minute per bar http://www.sierrachart.com/image.php?l=1410954951328.png |
[2014-09-17 17:13:08] |
We do not see a chart that is set to 1 minute per bar. For range bars, make sure you set the Bar Period Type to Range per Bar-Standard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
