Date/Time: Sat, 23 Nov 2024 01:46:39 +0000
SP5T5 (Top 50)
View Count: 152
[2024-09-13 20:03:19]
SavantTrader - Posts: 110
In an earlier post, I successfully (and painlessly) created a synthetic (custom) symbol for the SP5T1.
The SP5T1 consists of 10 of the largest companies from the S&P 500. Index constituents are weighted by float-adjusted market capitalization.
I now want to do the same for the SP5T5 (50 largest from the S&P 500).
Is there a simpler way of doing this, other than creating a synthetic (custom) symbol with 50 tickers and 50 multipliers?
The symbol [NDEXSP: SP5T5] is not supported, just as [NDEXSP: SP5T1] wasn't.
Thank you in advance.
[2024-09-13 20:55:29]
There is no other way to do this other than to create the Custom Calculated Symbol as you did for the SP5T1.
