Date/Time: Thu, 31 Oct 2024 10:13:01 +0000
VIX symbol
View Count: 187
[2024-09-13 19:23:25] |
singhraj4u - Posts: 5 |
I am looking for VIX Trading View equivalent symbol in Sierra chart. I couldn't find it. Can you please direct me to the symbol and do I have access based on the service I have opted for? |
[2024-09-13 19:26:03] |
John - SC Support - Posts: 35639 |
We can not speak to what symbol VIX was in Trading View. There are two main VIX symbols, one for the index itself which is found on the CBOE, and the other is the VIX Futures which are found on the CFE (CBOE Futures Exchange). We have data for both of these, but you need to know which one you are wanting in order to activate the appropriate exchange. Follow the instructions at the following link to activate the exchange you want: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-13 21:14:53] |
User150671 - Posts: 67 |
There is also the VOLX which is a CFD based on the VX futures which can be found under CFD - FXCM > VOLX Depending on your use case, this may or may not suit. |
[2024-09-13 23:09:29] |
I'm looking for CBOE Volatility Index
[2024-09-16 13:46:48] |
The CBOE Volatility Index can be accessed through our "CBOE Global Indices" exchange. Follow the instructions at the following link to set this up: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-16 18:28:39] |
Do I have to pay any additional monthly subscription for the CBOE or it is already covered in the package I have. Pls let me know.
[2024-09-16 19:23:16] |
There is an exchange fee for the "CBOE Global Indices" as there are for all the exchange options on our Denali Exchange Data Feed.
